Find Shortest Path
BramSmulders
Hello,
I wanted to use the Find Shortest Path node. I like the node, but I only understand the basics of it.
I want to use it to connect two points with Consider Turning costs turned on.
However; I want it to look like the red line I drew below. I want the line to do from A to B (or from B to A), take the  minimum amount of turns, but go at least one unit forward before doing so. I do not want to use the outer most points of the grid. Is this a function within the node?
My example files did not seem to work sadly.
Thanks!
-Bram
