Balloon setup using apply relationship node in DOP
oglop
Hi all, i'm new to houdini and have a question about balloon setup,  i successfully constrained the balloon to the root of wires,
i have several problems here.
1.  right now it works but not "correctly" constrained ( all balloons are constrained to point number 0 using apply relationship node , but it should be  balloon1-->wire 1 point 0,   balloon2-->wire 2 point 4 ...)
2. how to constrain the tip of each wire to each balloon ?
3. in single balloon setup there is an offset between balloon and wire tip at frame 1, how do i create the wire so that the tip point is located at the balloon bottom ?  and also how to use an object as wire root instead of origin, so the root can be animated ?
thanks
current effect in gif animation:
http://gfycat.com/BleakEmotionalElephantseal
balloon_02.hip
Edited by oglop
