oglop Posted January 12, 2015 Share Posted January 12, 2015 (edited) Hi all, i'm new to houdini and have a question about balloon setup, i successfully constrained the balloon to the root of wires, i have several problems here. 1. right now it works but not "correctly" constrained ( all balloons are constrained to point number 0 using apply relationship node , but it should be balloon1-->wire 1 point 0, balloon2-->wire 2 point 4 ...) 2. how to constrain the tip of each wire to each balloon ? 3. in single balloon setup there is an offset between balloon and wire tip at frame 1, how do i create the wire so that the tip point is located at the balloon bottom ? and also how to use an object as wire root instead of origin, so the root can be animated ? thanks current effect in gif animation: http://gfycat.com/BleakEmotionalElephantseal balloon_02.hip Edited January 12, 2015 by oglop Quote Link to comment Share on other sites More sharing options...
