Script the new H14 visualization architecture
asnowcappedromance
Hey guys,
In H14, we're supposed to be able to script the new visualization stuff with python, this is from the docs:
"New scriptable and extensible visualizer architecture replaces the custom attribute controls in the display options."
Does anybody have an idea how to access this? I went through the docs but I couldn't find anything about this topic.
Any pointers would be appreciated :)
Cheers,
Manu
There is also:
Powerful new visualization architecture:
    Intended to replace Guides framework
Is this about digital asset guide framework or just the viewport guides? I thought maybe H14 allows Soft Transform SOP like visualization where it shows colors but doesn't override actual colors nor creates them if they don't exist.
Thanks.
If you attach a visualizer to a particular node, a couple of hidden spare parameters will be created on that node. One of them is vis_data string which contains JSON like description of visualizer. This can be is easily modified with python. In case of scene visualizers, i didn't find python access yet.
Edited by Stalkerx777
