MartinuZ Posted January 19, 2015 Share Posted January 19, 2015 Hi, I'd like to create a custom global variable $E_PROJECT that defines a location on a local harddisk. I can do this with "aliases and variables" but these are not stored, and gone when I restart houdini.. I've tried houdini.env and 123.py but this doesn't work probably because of my syntax. so how do I do this? cheers, Martijn Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted January 19, 2015 Share Posted January 19, 2015 See this if you haven't already. It has examples of how to setup custom environment variables for Houdini. https://www.sidefx.com/docs/houdini14.0/basics/config_env Maybe post what's not working for you? Quote Link to comment Share on other sites More sharing options...
MartinuZ Posted January 19, 2015 Author Share Posted January 19, 2015 it works! (in the env file) The autocomplete feature does not recognize my custom variable (is this normal?) and it does not appear in the list of the "aliases and variables" menu, I assumed it would. that's why I thought it didn't worked.. thanks! Quote Link to comment Share on other sites More sharing options...
