Bullet, ConeTwistConstraint, strangle wobble effect
Juzwa
I'm struggling with it since yesterday and I don't know how to fix this. I get this strangle wobble effect on my Cone Twist Constraints:
These are my Cone Twist Constraint settings, pretty default:
I have 3 constraints:
1) glue to keep things together
2) hard to keep different structures together
3) cone twist to make the sim more natual, and  to break into bigger chunks.
I have a connected sop solver to my constrain network(cone twist). And an atrribute wrangle connected to relationship_geometry, with this expression:
if (@angle>0.2)
    removeprim(0,@primnum,0);
The angle in this constraint is barely going over 0.3.
Mainly I was playing with this expression since this is what is responsible for breaking the Cone Twist. When I set the @angle to sth small like 0.05 the wobble is gone, but the cone twist breaks ones sth hits the wall and It doesn't look nice. With higher values (@angle), the chunks are nicier, but there is more wobbling effect. I tried to combine this expression with @torque however I didn't see any differences.
So i think this is about the setting of the constraint itselt. I'm playing with values but can't fins anything right. What is the main cause of this wobble?
Hi ,
i have seen your file and i the reason of jiettring from two parts
the first one the wood
second from the big scattering points in your con digital asset
Also i edit your sopsolver code for the Hard con one by adding :
if (@torque>@breakTorque)
iv made for you some changes look at them, They are in red color nodes
i hope it is helpful
wobble.hipnc
