separate detached vdb sdf regions
jonp
Maybe I'm missing something obvious... I'm trying to split up separate regions in a VDB SDF.
The VDB Convert node doesn't seem to do as advertised.    Convert to Volume, with "Split Disjointed Volumes", doesn't actually do what it says.  See the attached file.  Two spheres converted to a VDB, then back to a volume results in only one VDB.
I don't really look forward to hacking this to work in a foreach node as my intention is to do this with a lot of fractured VDBs, which will be fairly slow...
Jon
The file is from Houdini 14.
split_fail.hip
  • 2 weeks later...
Yes... but I'm using VDB fracture and the number of pieces added up to a lot (thousands).  I was hoping to do it in a fast way.
But all is well now. A week or so during production is like an eternity, so I managed to make the issue magically go away...
