Juzwa Posted February 6, 2015 Share Posted February 6, 2015 Hi, I've decided to start doing modelling in houdini as well to learn H faster. Yesterday I've installeg H14 and I've noticed many changes. So I start this thead to keep all my question in one place (regarding modelling stuff). So.... 1) How can I make a loop selecion? I believe in H13 it was 'L' or 'I' shortcut for edges. It does not work in H14, 2) How can I remove an edge loop without deleting polygons? Quote Link to comment Share on other sites More sharing options...
ayidi Posted February 6, 2015 Share Posted February 6, 2015 1) Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted February 6, 2015 Share Posted February 6, 2015 1. Watch this => https://www.sidefx.com/index.php?option=com_content&task=view&id=3023&Itemid=404 2. If you have some suggestions (read: if you think the new shortcuts are bad), jump in into this topic and shout it loud! => http://forums.odforce.net/topic/21864-houdini-14-hotkeys-discussion-forked-from-h14-announcement-thread/ Quote Link to comment Share on other sites More sharing options...
ayidi Posted February 6, 2015 Share Posted February 6, 2015 Tip: read the messages in the viewport: 2) Select the edge loop and press delete 1 Quote Link to comment Share on other sites More sharing options...
Juzwa Posted February 10, 2015 Author Share Posted February 10, 2015 Sorry for sucha late response, but thanks guys, this is very helpful! I'm having some problems with viewport, the messages at the bottom use to dissapear after some time. Maybe this can be changes somewhere in the settings. As for removing edges: pressing delete on selected edges removes points as well, which leads to deleted polygons. I'm rather looking for a tool like in maya (delete edges) and max (ctrl + backspace) Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted February 10, 2015 Share Posted February 10, 2015 As for removing edges: pressing delete on selected edges removes points as well, which leads to deleted polygons. I'm rather looking for a tool like in maya (delete edges) and max (ctrl + backspace) DissolveSOP Quote Link to comment Share on other sites More sharing options...
Juzwa Posted February 23, 2015 Author Share Posted February 23, 2015 Hi! I have a new question: How can I extrude my object to get some thickness? I have tried extrude SOP and its terrible. The extruded and original geometry splits into individual faces, can't fix that with any setting. Fuse doesn't help Quote Link to comment Share on other sites More sharing options...
iamyog Posted February 23, 2015 Share Posted February 23, 2015 polyExtrudeSOP with Keep Points Shared as Average Positions ? Quote Link to comment Share on other sites More sharing options...
Juzwa Posted February 23, 2015 Author Share Posted February 23, 2015 unfortunately polyExtrude is even wors. Is extruding along some strange directions, even though my normals are correct Quote Link to comment Share on other sites More sharing options...
iamyog Posted February 23, 2015 Share Posted February 23, 2015 Should work on a geometry with correct topology. Can you upload an example file ? Quote Link to comment Share on other sites More sharing options...
Juzwa Posted February 23, 2015 Author Share Posted February 23, 2015 (edited) My topology is not correct. I use convertVDB to create a proxy geometry for a tyre temp.hip Edited February 23, 2015 by Juzwa Quote Link to comment Share on other sites More sharing options...
iamyog Posted February 23, 2015 Share Posted February 23, 2015 See attached file temp_fix.hip Quote Link to comment Share on other sites More sharing options...
Juzwa Posted February 23, 2015 Author Share Posted February 23, 2015 Thanks Quote Link to comment Share on other sites More sharing options...
