Disable auto-launch Apprentice if Master license not available
there is an environment variable you can set in your houdini.env file
Maybe one of these will work?
HOUDINI_NOHKEY
    Setting this environment variable will prevent Houdini from launching the
    apprentice license auto-installer and the license administrator
    when a license check fails.
HOUDINI_NOHKEY_APPRENTICE
    apprentice license auto-installer but will cause it to immediately launch
    the license administrator when a license check fails.
Edited by jkunz07
Thanks for the reply! Sadly niether of those are working for what I need. Do you (or anyone) know the command to check how many licenses are available? i thought it was sesictrl.exe -i but that doesnt seem to work for me. (I may have a permissions problem, just like to check)
