Python Scripting defaults on parameters on HDA
EwanW
Hi!
Was just wondering if anyone has a good way of setting defaults on an HDA through python?
Sure it must be fairly simple but I can't seem to find a specific command. Ideally it would be the same as clicking Copy defaults from node?
Thanks for any suggestions.
The defaults are normally set with the parameter interface stuff (like a default float value or whatever other parameter). Though it's possible to do with Python as well and run it when the node is created. Can you be more specific about what you're trying to do?
http://www.sidefx.com/docs/houdini14.0/hom/hou/Parm
http://www.sidefx.com/docs/houdini14.0/hom/assetscripts#node_initialization_scripts
I have a node which I am turning into an HDA with a script. I want the settings at object level to be saved as defaults as if I had used Type Properties/Save Defaults from Node.
I want to take the object level parameters and save them as defaults when the HDA is created.
