'Extract content' simultaneously
HI all,
My question: Can I 'extract contents' of multiple alembic container nodes simultaneously?
I have an imported alembic geometry sequence, and I want to group certain areas of the geo for use in various dops sims.
I loaded the alembic as 'Houdini geometry', however, inside the alembic at obj level, I have hundreds of individual alembic 'container' nodes that have individual Houdini geo nodes inside them.
This would be fine if it was just a few nodes, as I can obviously rmb > extract contents. However this doesn't work for me on multiple nodes.
Is there some-kind of shelf tool/script I can run? Or a certain check box on alembic import I may have missed that will give me 100% Houdini geo nodes?
Sorry if this is a bit of a layperson question - One of the pitfalls of being self taught :)
Thanks!
(H 14.0.201.13)
well, I had the same problema and created a shelf tool. Just create a new tool and paste this script. Hope it still works.
import hou
# selection functions
# this one selects node objs and textures and return the selection
def importer_selectNodeObjsNTextures():
    import toolutils
    # Get active sceneViewer
    sViewer = toolutils.sceneViewer()
    # Ask user select nodes to switch tex
    selection = sViewer.selectObjects('Select nodes to switch tex, press enter to confirm', allowed_types=('geo',), allow_multisel=True)
    # Check that selection wasnt empty
    if selection == ():
        hou.ui.displayMessage('Nothing selected, terminating tool', severity=hou.severityType.Error)
        return (None)
    selection[0].setSelected(0, True)
     # Ask user select the parent no to generate the inverse matrix
    texture = hou.ui.selectNode()
    #parent = sViewer.selectObjects('Select parent, press enter to confirm', allowed_types=('*',), allow_multisel=False)
    if texture == ():
        return (None)
    return (selection, texture)
# this one select node objs and return the selection
def importer_selectNodeObjs():
    import toolutils
    selection = sViewer.selectObjects('Select nodes, press enter to confirm', allowed_types=("geo",), allow_multisel=True)
    if selection == ():
        return (None)
    return (selection)
def importer_copyObjs(selection):
    if selection[0].parent() != None:
        geoName = 'NEW_' + selection[0].parent().name()
    else:
        geoName = 'newGeo'
    newGeo = hou.node('/obj').createNode('geo', geoName)
    newGeo.setColor(hou.Color((1, 1, 0)))
    newGeo.children()[0].destroy()
    # iterates throught selection to find for 'alembic' nodes and outputs a list with these nodes
    oldList = selection
    loop = 1
    while loop == 1:
        outputList = []
        alembicNum = 0
        for obj in oldList:
            childNum = len(obj.children())
            if childNum > 0:
                for child in obj.children():
                    outputList.append(child)
                    if child.type().name() == 'alembic':
                        alembicNum+=1
            if obj.type().name() == 'alembic':
                outputList.append(obj)
                alembicNum+=1
        oldList = outputList
        if len(outputList) == 0:
            print 'No alembic nodes in the selection'
            return
        if len(outputList) > 0 and len(outputList) == alembicNum:
            loop = 0
    for sopFile in outputList:
        geo = sopFile.parent()
        grpNode = sopFile.createOutputNode('group', geo.name())
        grpNode.parm('crname').set(geo.name())
        xform = geo.worldTransform()
        xformNode = grpNode.createOutputNode('xform', 'parent_xform')
        xformNode.parmTuple('t').set(xform.extractTranslates('srt'))
        xformNode.parmTuple('r').set(xform.extractRotates('srt'))
        xformNode.parmTuple('s').set(xform.extractScales('srt'))
        xformNode.parmTuple('p').deleteAllKeyframes()
        xformNode.parmTuple('p').set((0, 0, 0))
        #grpNode.setDisplayFlag(1)
        #grpNode.setRenderFlag(1)
        hou.copyNodesToClipboard([grpNode, sopFile, xformNode])
        hou.pasteNodesFromClipboard(newGeo)
        grpNode.destroy()
        xformNode.destroy()
    # connect all groups to a merge node
    mergeAll = newGeo.createNode('merge')
    i = 0
    for child in newGeo.children():
        if child.type().name() == 'xform':
            mergeAll.setInput(i, child)
            i+=1
    mergeAll.setDisplayFlag(1)
    mergeAll.setRenderFlag(1)
    outputGeo = mergeAll.createOutputNode('rop_geometry', 'Output_geo')
    return outputGeo
importer_copyObjs(importer_selectNodeObjs())
Hey gui,
Thanks so much for that! It doesn't work straight out of the box, but certainly enough here for me to get my chops around & get something going!
What doesnt work? If you can share some hip, I will fix it.
