emitters and expressions
  so I am new in Houdini and I am trying to deliver my shot now haha.
  I have a FLIP setup with a custom emitter, and I am trying to animate the emission with expressions and (animated) custom attributes coming from the geo emitter...  So my questions are:
1) how can I use a noise() expression in the y scale of my emitter only?  Coming from Maya, I was using noise(time) all the time but can only use rand($F) in houdini right now
2) can a POP source use a custom attribute coming from the geo of the emitter, created with Attribute Create?  I read my local variable on the emitter but can't use it
I can't work with VOPs currently, it's a little bit too complicated, as it's my first houdini scene.  I've tried but can't make it do what I want.
Thank you!
Use CHOPs to do that or noise() function. Equivalent of time in Houdini is $T. rand() gives you values between 0 and 1. Use fit01() to remap values.
Yes, if you specify Inherit Attributes under Attributes tab of POP Source.
Edited by Pradeep Barua
If you can't understand expressions then use manual keyframes. There is no side effects of it only thing it's not procedural.
To use CHOPs in a parameter, right click > Motion Effects and choose presets fron dropdown.
