papicrunch Posted March 5, 2015 Share Posted March 5, 2015 Hello, Is there a way to set an otls scan path per hip file ? Thank papi Quote Link to comment Share on other sites More sharing options...
pbarua Posted March 5, 2015 Share Posted March 5, 2015 I'm not sure about that but you can include otls in hip itself. it's not ideal if you are updating otls frequently. Quote Link to comment Share on other sites More sharing options...
prashantcgi Posted March 5, 2015 Share Posted March 5, 2015 Hi thomas Add @/otls to otls scan path HOUDINI_OTLSCAN_PATH=@/otls;&; so when read your HIP file your $HIP path will read the $HIP/otls directory From Houdini docs:- @ Typically expands to the directories on the HOUDINI_PATH. So, if the HOUDINI_PATH is... $HIP$HFS/houdini$HOME/houdini Quote Link to comment Share on other sites More sharing options...
