[solved] Does SOP_Node::select() work?
Nothing is being selected in the viewport.
Also tried the SOP_Star example that uses select(GU_SPrimitive); and it doesn't work as well.
H14/H13
Edited by ayidi
  On 3/8/2015 at 12:04 AM, edward said:
Did you put it down from the viewport? Selections show only when the highlight flag is enabled, which is off when you put a SOP down from the network view.
I was doing it from the Network View.
Now that I'm setting the highlight flag manually it works in both situations.
Perfect, thank you for clarifying. Is there any documenation of this behavior?
setHighlight(true); // make sure to set it in the constructor
select(*group);
Edited by ayidi
  On 3/8/2015 at 3:33 AM, edward said:
I'm not sure if there's any documentation, I haven't looked. I would assume so though since this has been the way for all SOPs since H5. If you can't find any, please submit docs bug.
I didn't find any documentation but the behavior is caused by toolutils. Houdini calls toolutils.genericTool when the node is a manager or the current pane is not a scene view, toolutils.genericTool doesn't set the highlight flag of the node.
Example:
Custom SOP (Other)
- SceneViewer: soptoolutils.genericSopNodeFilterTool
- NetworkEditor: toolutils.genericTool
Box SOP (Generator)
- SceneViewer: soptoolutils.genericSopNodeGeneratorTool
Placing nodes from the scene viewer has better default behaviors such as automatically connecting nodes among many other features depending on the node type (faster). However, the toolutils.generictool allows the user for more control such as node placement and connections (slower).
I should starting placing nodes from the scene viewer more often.
