point solver not working in foreach
Hi, guys.
So there is a problem when i created a point solver SOP in foreach. I have three moving point which i want generate their trail each, so i merge their last frame in solver SOP.
After above steps, the point haven't get a nice trail, it looks like only one point works, the rest of them just disappeared.
I will be appreciated if someone can help me out.
Thanks.
point_solver_in_foreach2.hip
Edited by wateryfield
Well, you are asking for trouble here - throwing DOP network inside foreach, expecting to have multiple instances of it. I'm actually surprised that it doesn't crash instantly...
Usually you can skip the foreach - wrangles are really nice workaround. Or if there is no other way - you can put the foreach inside the sop solver.
  • Like 2
Thanks for your advice. Rayman.
But throw a DOP network do you mean a POP network or make point as point object. It seems too heavy.
So put the foreach inside sop solver was also in DOP network, i try foreach inside solver, seems not working too.
And the Wrangle way, i will have a try with loop.
Thanks.
I mean that using sop over inside foreach is the same as using dop network inside foreach - both are basically the same and won't work as expected.
Foreach inside SOP solver or DOP network will work - at least it always work in my cases.
:mellow: Forgive my poor English, I totally misunderstood what you meant.
Now it works, last time i just forgot the eachAttribute.
Thanks, Rayman.
