J_rom Posted March 9, 2015 Share Posted March 9, 2015 Hi all, So I'm trying to split a group of objects into two groups based on a distance or something better. See here: The Blue group have six balls close to each other, same for the Green group, So, to split the two groups, I want to use the space between them if possible. What I tried is this: I've connected a point SOP to Group1, then attached a foreach SOP to the point SOP, and plugged a Ray SOP to the each SOP inside foreach, since Houdini document stated that the Ray SOP needs points as input 1 to work. But .. I couldn't figure out how to use it probably. So, what can I do? splittogroups.hipnc Quote Link to comment Share on other sites More sharing options...
edward Posted March 10, 2015 Share Posted March 10, 2015 No time to look at .hip files but maybe try the Cluster SOP: http://www.sidefx.com/docs/houdini14.0/nodes/sop/cluster (YMMV) Quote Link to comment Share on other sites More sharing options...
