Houdini pop up dialog windows are behind main window
Hi all, I have a very annoying problem where almost all the popup dialog windows like Type Properties or the Expression Editor appear behind my main Houdini windows.
I have a 3 monitor setup but only use 2 for Houdini:
+   Main   + +  Second  + +Other+
+  Houdini + +  Houdini + +     +
Doesn't seem to matter which window I use though as the diaogs appear behind the main and Second Houdini windows.
Info:
Houdini 13.0.582 (same problem with H14 though)
Window 7
Is there a setting to make diaogs always on top of the main windows somewhere?
Thanks!
G
This is very common on Windows mate. I always see it if I bring up for example display options over the viewport and then click on the viewport outside this dialog. So either I close it so I don't have to press D several times to restore it, or I move it slightly off the viewport.
Hard to get support to resolve this though.
It happened a lot to me too to the extent that I already see as a "normal" behaviour. I worked with 2 monitors with different solution, not sure if that's make the problem worse, but its really annoying and sometime there is no way to bring the dialog box upfront and I am force to kill houdini.
OK I fixed it with AutoIt.
What to do:
  1. Download and Install AutoIt: https://www.autoitscript.com/site/
  2. Extract Houdini_PopupsOnTop.au3 from Houdini_PopupsOnTop.zip attached to this post.
  3. Double click Houdini_PopupsOnTop.au3
You should see an AutoIt tray icon if it's running correct.  Now when you use Houdini ALL the popups should be set to always on top.  This is the functionality I wanted, let me know if you'd like something else, for example just put the popups to the foreground but not always on top.
Also this means we can pretty much do ANYTHING to ANY Houdini windows on Windows so if there's any other weird issues let me know.
Satan did make a brief appearance when I tried to do this in Python but we had some beers and everything's OK.
TNKS!
G
So as soon as I made this one of my colleagues requested the put windows infront but not always on top feature.
There are some edge case problems I don't have time to fix right now but it works pretty well and these are only in the "To Front" option not the "Always On Top" option.
I've attached a zip with the script and compiled exe (with Houdini icon for extra pzazz)
Now if you right click on the tray icon you'll get 3 options:
Aways On Top - Sets any Houdini popups to be always on top (default)
To Front - Just tries to set the popup infront of other Houdini winodows
Disabled - Do Nothing
You can also click "Set Open Windows to On Top" to do that.
Let me know if you find any bugs etc.
TNKS!
Houdini_PopupsToFront.zip
