Getting Alpha in refraction with mantra?
Cribbed notes from these 2 places:
http://houdini.dreamerzstudio.net/?page_id=67
http://forums.odforce.net/topic/12291-raytracing-and-alpha-question/
To get this:
post-7292-0-50533100-1427762206_thumb.jp
Probably not quite right, but should be enough to get you started. :)
refract_alpha.hipFetching info...
Looks like Dany Bittel's layered PBR shader does this automatically and has a bunch of other cool features, probably worth getting it if you need a good material base to work with.
http://forums.odforce.net/topic/18353-pbr-all-purpose-layered-shader/
calling "trace()" will let you easily grab the Alpha or Opacity (instead of just the color).  what's more, if you tag the rays as "primary" rays, then "Matte" and "Phantom" will still operate appropriately, which is kinda neat (ie, the trace rays won't hit Phantom objects and Matte will knock holes in the resulting alpha).  it's a great way to collect reflections and refractions (with mattes) for later compositing.
