Scripted way of some UI operations?
Linghaoli
Hi Guys:
  I am wonder how to do the following in either python or hscript:
1. Set "Render Beauty Pass Only" in the checked in the Flipbook render gui
    The "vieweroption" cmd seems have an arg -F, which is to set the flipbook optionis,
    However what are the available flipbook options can be used? Same ones in cmd "viewwrite" ?
2. Maximize current panel( bascially what the Ctrl + B shortcut does. )
Did some googling but couldn't find anythin.. figured might as well ask around here :)
thanks a lot!
-ling
  • 2 weeks later...
found out how to do these, just put it here in case anyone needs it later...
for 1:
the -B flag should do it..
for 2
# maximize
hou.hscript("pane -f 1 %s" % pane.name())
# set it back
hou.hscript("pane -f 0 %s" % pane.name())
