VDB Export Arnold Maya
none
Someone should tell the Arnold guys to upgrade to OpenVDB 3.
The volume_openvdb plugin that comes with the latest MtoA does support OpenVDB 3.0.
If the OpenVDB version was the problem, there would have been an error logged by MtoA to the Output Window in Maya.
Edited by stblair
If they're using OpenVDB 3, then I don' think they should have a problem reading the .vdb files output from H14 by default. Unless of course, they use OpenVDB 3 but disabled blosc support.
If they are using the latest MtoA. But the OP didn't specify that, or any other details.
  • 3 weeks later...
