Determine Material Type From Python?
Atom
Hi All,
I have been trying to determine what type of material I have in any given node. For instance the difference between a Clay material and a Mantra Surface. Each node does have a .shaderType() method but they both return the same value, vopnetwork...
Is there any other method for distinguishing the difference between material nodes other than grunt checking for the presence or absence of parameters using TRY/EXCEPT?
Thanks
