accessing a variable in Ripple SOP
What would you guys do to access an attribut value inside a Ripple SOP?
say I would like to scale the force of the ripple depending on the value of this attribut on a point basis? (for example the Cd attr)
when i write down this, i get errors:
0.5*point("../point1", $PT, "Cd", 0)
thank you!
Click on Edit Vex Function, go to the Code tab and at the last line where it says "P += up * dist;"  and change it to "P += up * dist *Cd; "
If you drop a Paint SOP and paint black, the ripples will not appear there :)
