Mantra: OpenSubdiv CC much slower than Mantra CC. Why?
So, I've been doing a lot of rendering recently and have noticed that if I set an object to be rendered as OpenSubdiv Catmull-Clark (via Render Polygons As Subdivision), Mantra takes several times longer to prepare the geometry than if I were to use Mantra Catmull-Clark algorithm. Is it simply because Mantra isn't optimized to use OpenSubdiv, or is there some other reason behind it?
I'm just curious.
I tried subdividing a cube (with the Subdivide SOP though, not at rendertime) - and OpenSubdiv was slightly faster there every time. Maybe your mesh contain triangles or other oddly shaped polygons that OpenSubdiv have a harder time working with? I don't know.
I'm just curious.
OSD isn't thread safe for the operations that mantra currently uses (updating the Hbr topology).  So, only a single thread can refine at a time.
The SOP doesn't process groups (which is an outstanding bug), which may be one reason there's a performance boost there.  But in general, I believe the OSD code is a little more efficient than the Houdini libraries.
Check the threading performance too IIRC.
Indeed, this looks like the culprit! I just made a quick test and OpenSubdiv CC uses a single core only, while Mantra CC takes advantage of almost all cores. Geometry preparation of a scene consisting of about 1.3 million primitives took Mantra CC around 40 seconds, while with OpenSubdiv CC it reached a whopping 11 minutes. This disproportion is quite extreme.
A few days ago I submitted a report regarding this issue. Hopefully it will be fixed someday...
