Guest tar Posted April 28, 2015 Share Posted April 28, 2015 (edited) Calling all Windows users .Help me cross over to the dark side! In evaluating alternatives to OsX for increased Houdini performance, I'm currently finding H14 in Windows 7 SP1 to be quite crashy. Is this normal in Windows land, and, should I do anything special to make it more stable? i.e. crashes a few times per hour in normal use. All advice welcome! Nvidia Gtx980, drivers 350.12 H14.0.314 Windows 7 SP1 Intel 5680 x2 64Gb Ram Edited April 28, 2015 by tar Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted April 28, 2015 Share Posted April 28, 2015 Log a bug Can't help because on my workstation it's rock solid. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted April 28, 2015 Share Posted April 28, 2015 Good to hear, sounds like I should be able to get a very stable system. ~50% of bugs have been logged - using the auto bug logger. Quote Link to comment Share on other sites More sharing options...
JonathanGranskg Posted April 28, 2015 Share Posted April 28, 2015 Yep. In my experience Houdini on Windows is definitely unstable compared to Linux. I can simulate a lot more particles/voxels on Linux than I can on Windows. It's almost ridiculous. No idea how to make it more stable other than what mantragora said. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted April 28, 2015 Share Posted April 28, 2015 the instability is just in the general interface, not many simulations yet. i.e. RMB in the Vop-Sop crash sometimes etc. I'll start analysing the crash reports more then. Quote Link to comment Share on other sites More sharing options...
michael Posted April 28, 2015 Share Posted April 28, 2015 historically Houdini has been sensitive to graphics driver issues...you may want to ensure you're using the appropriate (this doesn't always mean latest) drivers for your card. 1 Quote Link to comment Share on other sites More sharing options...
Guest tar Posted April 28, 2015 Share Posted April 28, 2015 (edited) thanks Michael - the driver issues should show as GL lines in the crash report ya? I'll test out the different driver too. Edit: Looks to be solved by dropping to Nvidia driver 347.88 Edited April 28, 2015 by tar Quote Link to comment Share on other sites More sharing options...
Georgie Posted April 29, 2015 Share Posted April 29, 2015 340.52 is the only version I've found to not give me any issues in any software. I'm running a GTX 480 though. I've also set my TEMP and TMP variables to a custom folder that I clean up every now and then - otherwise I get an absurd amount of crashes from Maya and Houdini despite having a lot of free space on my HDD. No idea why Quote Link to comment Share on other sites More sharing options...
malexander Posted April 29, 2015 Share Posted April 29, 2015 I tried the WHQL Nvidia 350 driver for a while, but it kept bluescreening Windows when the monitor or GPU powered down on standby. So it didn't remain installed for very long. I suspect it had something to do with my dual-scalar 4K monitor that uses DP1.2 MST. While I did have it installed I didn't notice any graphic corruption at least, but admittedly my test window was pretty narrow. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted April 29, 2015 Share Posted April 29, 2015 Makes more sense now - the geforce drivers are totally geared/tweaked for games - never knew how much until reading up on GPUs! This gamedev post talks of the shenanigans: http://www.gamedev.net/topic/666419-what-are-your-opinions-on-dx12vulkanmantle/#entry5215019 Quote Link to comment Share on other sites More sharing options...
fathom Posted April 30, 2015 Share Posted April 30, 2015 for me, the biggest problem with houdini on windows is that houdini tends to use a lot of ram and windows doesn't seem to like that. i find doing anything memory intensive requires a lot of relaunching to keep from going over the physical ram limit. Quote Link to comment Share on other sites More sharing options...
