yjcnbnbnb200 Posted May 6, 2015 Share Posted May 6, 2015 In thinkboxsoftware stoke 2.0 we can generate millions of particles from emitter like geo or particles invery fast and cache it out into prt sequences, can we do the same thing in Houdini 14? Quote Link to comment Share on other sites More sharing options...
Mandrake0 Posted May 6, 2015 Share Posted May 6, 2015 YES for millions particle and plugin for PRT export.... by billions particles you have to test it... it should be possible with much RAM also depending on your requirements.... http://www.flipswitchingmonkey.com/2015/01/prt-export-from-houdini/ i never used this exporter so you have to test it. Quote Link to comment Share on other sites More sharing options...
yjcnbnbnb200 Posted May 6, 2015 Author Share Posted May 6, 2015 YES for millions particle and plugin for PRT export.... by billions particles you have to test it... it should be possible with much RAM also depending on your requirements.... http://www.flipswitchingmonkey.com/2015/01/prt-export-from-houdini/ i never used this exporter so you have to test it. Thanks I will test! Quote Link to comment Share on other sites More sharing options...
