converting seconds to epoch time and back.
I am using the Table Import SOP to convert from human readable time to seconds...
2015-05-13 11:24:17
This converts using the convert date to seconds menu flydown in the SOP as:
 1431534257
Which is great, but I now need to go back the other way?  is there a way to format a string sequence back as a human readable date?
The short answer is yes. The long answer is this... I'm getting back '2015-05-13 11:24:17' so the numbers seem sane.
https://docs.python.org/2/library/datetime.html#strftime-and-strptime-behavior
from datetime import datetime
foo = datetime.fromtimestamp(1431534257)
readable = foo.strftime('%Y-%m-%d %H:%M:%S')
print readable
Edited by lukeiamyourfather
Great this looks really promising.  Now I only have to apply this. I'm not so good in python, this is what I got and its not quite working.  What I would like is ideally to read the timeStamp from an attribute, and convert to the readable date, and output as a string attribute. I created both attributes before the pythonSOP.
node = hou.pwd()
geo = node.geometry()
# Add code to modify contents of geo.
for point in geo.points():
    ts = point.attribValue("timeStamp")
    foo = datetime.fromtimestamp(ts)
    point.setAttribValue("Date", readable)
TimeStamp_V1.hip
ok really dumb error... forgot to import datetime  :blush:
now its working
node = hou.pwd()
