mosy252 Posted May 22, 2015 Share Posted May 22, 2015 Is there any way to create rim shader in arnold for houdini? Just like this link: https://support.solidangle.com/m/mobile.action#page/3868038 Quote Link to comment Share on other sites More sharing options...
hkspowers Posted May 23, 2015 Share Posted May 23, 2015 (edited) Not sure if Arnold for Houdini works like Arnold for Maya off the shelf when it comes to converting existing shaders to render in Arnold, but you can get that same efffect with the ramp shader in Houdini. https://www.dropbox.com/s/3u5i8y4yic3c2rl/untitled.jpg?dl=0 Edited May 23, 2015 by hkspowers Quote Link to comment Share on other sites More sharing options...
mosy252 Posted May 23, 2015 Author Share Posted May 23, 2015 thanks for your answer.did you use the houdini ramp or the arnold ramp? I think houidini ramp does'nt work with arnold and the arnold ramp doesnt have this kind of effect. i am new to houdini .can you upload your network shader,for this shader please? Quote Link to comment Share on other sites More sharing options...
mosy252 Posted May 24, 2015 Author Share Posted May 24, 2015 please .no body else can answer my question? Quote Link to comment Share on other sites More sharing options...
Juraj Posted May 26, 2015 Share Posted May 26, 2015 Hi, recently I've been trying to reproduce rim shader as well. However I couldn't find Houdini's quivalent for Maya's sampler info. I ended up using AO shader with reversed white and black colors. It gave me kind of similar effect. Another way of doing this would by passing attributes but then you are limited by geometry resolution. Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted May 26, 2015 Share Posted May 26, 2015 It looks like you should be able to use the shading state to get normal and incidence vectors https://support.solidangle.com/display/AFHUG/Shading+State Then math to get dot of normal and incidence vectors https://support.solidangle.com/display/AFHUG/Math+Shaders The result of the dot would get fed into the arnold ramp. I don't have access to arnold in houdini at the moment to test though. Quote Link to comment Share on other sites More sharing options...
Juraj Posted May 26, 2015 Share Posted May 26, 2015 thank you very much Quote Link to comment Share on other sites More sharing options...
mosy252 Posted May 27, 2015 Author Share Posted May 27, 2015 (edited) thanks all of you for helping me. Edited May 27, 2015 by mosy252 Quote Link to comment Share on other sites More sharing options...
