Houdini Path Environment
dszs
Hi guys,
            I have a few question about setting custom path and variables in houdini.
1) Where is the .env file?
I cant find any file in the installed houdini folder where there is a .env file.
I am using Linux, Ubuntu 14.0.4
2) How do I set the path to be permanent?
    For instance, I changed my $JOB path by using
source houdini_setup
export JOB=/mnt/Artist/
But this only works for that session, how do I store it permanently?
3) How do I create a new variable and store it permanently?
For instance, I can add a new variable through the Aliases/Variable. But it only appears on that instance of Houdini.
Sorry for the long post and if the questions don't make much sense. This is the first time I am attempting to customize my houdini through the terminal. All the help is greatly appreciated!!
-Darren
cd ~/houdini14.0
gedit houdini.env
add this line
JOB /mnt/Artist
there and save.
Open Houdini > press ALT+SHIFT+T > type echo $JOB
If color is yellow then it will print /mnt/Artist.
Hi pradeep,
                 Thanks alot! It worked like a charm, I do have another question though. How do I add a custom path into the selection window like the image below?
Really appreciate your help!
post-11532-0-44696600-1432606948_thumb.j
