Group geometry by scattered points/UV projection
Not really sure on how to formulate this question, as I'm new to Houdini, but I will try my best.
I'm trying to work out a UV projection on packed geometry that I have animated to fracture.
I need to get the primitive faces that are facing the camera into one group for the UV projection, and the "inside" in one to get materials there.
I was told by a more experienced Houdini user that it should be possible to scatter (a huge amount of) points on the surface of the geometry and create a surface group from that. I don't know how that could be done however. Do I somehow tell the geometry that the faces scattered with points is one group? Or do I somehow attach those points to the geometry and project the texture on them?
If anyone have other suggestions to how I could UV project on packed primitives I'm open to suggestions, as you can see from the attached images, the projection stretches as soon as the geo starts breaking.
Kine
post-12936-0-40698900-1432642826_thumb.p
post-12936-0-56831100-1432642949_thumb.p
post-12936-0-24448500-1432642969_thumb.p
