HOUDINI THE MEMORY DESTROYER (?)
Just wondering if anyone else exp this.
Houdini runs great on my box with flipbooks, etc, but when I use ROP driver to save a bgeo or obj seq, it gobbles up all my disk space during the write. Its a decent res fluid mesh, and about 200 frames, so I think I get it why it wants to use that memory during the write, but is there a way for me to change the dir path for that mem usage, away from my 500 GB HD and maybe to the 1TB? It's driving me a lil crazy, so any advice is appreciated, thanks.
Specs:
Mac Yosemite 10.10.2
2009 Nehalem
2x2.26 GHz Quad Xeon
24 GB RAM
500 GB SSD (main HD)
Not sure what you're asking - are you talking about RAM or HDD space ?
If it's the former - try restarting Houdini before you commit to your final resolution sim. Or render through the command line.
When it comes to HDD space, there are a couple of things you can do to minimize the usage - use .bgeo.sc files ; don't write out fields that you will not be using (ex; importing temperature out of a simple smoke sim that you're intending to render as is); delete attributes that you don't need before writing to disk.
And of course you can create a folder on your HDD to use for writing out data and point the ROP to it .
Fields and particle sims tend to pump out a lot of data tho. 200 frames could easily go to 50 gigs for a relatively simple sim. And that's coming from me - just a home user. I can totally imagine the fancy stuff on Vimeo being into the 100's of gigabytes.
Yeah, sorry I neglected to also mention a big note.
ALL the memory comes back after I quit.
The bgeo files are fine, and about 30GBs, but its during the output that the hard drive chokes up and ROM gets eaten.
