syzmatrix Posted June 5, 2015 Share Posted June 5, 2015 Hello there, I created a subnetwork and some nodes inside it. Now I want to edit subnetwork's interface to create some parameters, and I used to create them by dragging them from nodes. Now I want to directly create some parameters under the root. For example, I want to create a parameter called "constraintName", and the type is "String". How can I do this, without dragging from the nodes. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
michael Posted June 5, 2015 Share Posted June 5, 2015 use the gear and Edit Parameter Interface Quote Link to comment Share on other sites More sharing options...
pbarua Posted June 5, 2015 Share Posted June 5, 2015 Click on gear icon > Edit Parameter Interface... > Drag and drop String from left side to under root or click on right arrow > then change label and name. Quote Link to comment Share on other sites More sharing options...
