[Pyro] animated constainer, bounds from object level
Juzwa
1) How do I take the bounds of the moving object and use them as a constainer for my sim? "bbox("/obj/myObj", D_XSIZE)" does not work
2) How do I make pyro to calculate the movement of the container properly? What I mean is that the object is moving and I need just the bounds close to the object to calculate. Does appropriate applying the bounds do the trick? (i guess not)
Edited by Juzwa
1) Object nodes have no specific geometry, only SOP nodes do. The data for an Object node is a world transform (4x4 matrix). Instead, a common convention is to use a Null SOP named OUT as the node to render/display inside an object. So you then would do "bbox("/obj/myObj/OUT", D_XSIZE)"
