cs00bren Posted September 5, 2002 Share Posted September 5, 2002 Hello I'm a 3-year student doing my project on animation using Houdini. The project is to see if I can make a command that then you clone a model it changes some pre-design variables like size, shape, quantity of particles, speed of travel etc. This is so that if you clone an object 100 times you get hopefully 100 models with slightly different appearances. Eg a space ship scene with 100 ships all the same style but appear different. I Quote Link to comment Share on other sites More sharing options...
danteA Posted September 5, 2002 Share Posted September 5, 2002 I'd recommend simply learning Houdini and it will become very apparent as to how you can do this. Don't forget the Copy SOP. Also, don't forget to check out the tutorials on the sidefx homepage: http://www.sidefx.com/community/learn For some inspiration look at the Effects forum here and read the challenges. Quote Link to comment Share on other sites More sharing options...
