Join sop issue
boby
Hello,
I have a problem with the join sop. It seems to remove some points/edge in my geometry.
Do you have any workaround to correctly join those primitives (in order to use a resample node on it) or just know why join is doing that?
geometry should be locked in the hip file.
Thanks !
joinIssue.hipnc
i am not sure whether the join sop used to perform better in comparable situations. i mean, in a polyline all vertices are connected in a row, so once it reaches a tip, it just has to build a new polyline to connect the twigs.
maybe a solver could redraw the curves by starting at one of the tip points (that has no neighbors nearby) and iterate through a point cloud reconnecting points by connectivity and proximity?
