SHOP based intersection gradient
Hi guys.
I'm working on a wetmap for where procedural ocean meets sand on an island.
basically, I don't want to have to subdivide the island geometry and do a point based color transfer to create a gradient.
I would like to achieve this effect in SHOPS, independent of how lowres the render geometry may be.
I thought of using an occlusion node. but I would only get the proper 0-1 gradient I want at angles <= 90deg
pc open is dependent on point count as well, so I've ruled that out.
Surely there's a smart way to analyse the intersection points of the objects primitives?
Edited by kvdo
Thanks anim, thought about this as well, but got nervous thinking of converting a 1000x1000 unit ocean grid to sdf. looks like you can make it pretty lowres and it still works. don't even have to volume extrude the grid as I initially thought.
I suppose there's no way to reference the file in shops without caching it? I see the op: syntax doesn't work. probably for reasons around the way ifd's work?
Edited by kvdo
