nran Posted June 29, 2015 Share Posted June 29, 2015 Hey, guys A question here, anybody know how to convert the flip surface field to a surface SDF in flip? i know the sopsolver can do it but is there any way to do by using microsolver in dop? There is Gas geometry to SDF node, can i use this? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
anim Posted June 30, 2015 Share Posted June 30, 2015 the surface field in flip is already SDF, what are you trying to do? Quote Link to comment Share on other sites More sharing options...
nran Posted June 30, 2015 Author Share Posted June 30, 2015 the surface field in flip is already SDF, what are you trying to do? try to use gas surface tension in flip, but looks like it's not working if i plug the gas surface tension dop directly into flip solver. any idea why? Quote Link to comment Share on other sites More sharing options...
anim Posted July 1, 2015 Share Posted July 1, 2015 you need to plug it in Volume Velocity input for it to have any effect on flip Quote Link to comment Share on other sites More sharing options...
nran Posted July 1, 2015 Author Share Posted July 1, 2015 you need to plug it in Volume Velocity input for it to have any effect on flip oh~ ~ thanks very much man! works! Quote Link to comment Share on other sites More sharing options...
