Jerome_K Posted July 4, 2015 Share Posted July 4, 2015 Hi Folks I m wondering if someones found a easy way to use Houdini 14.0.361 with a mantraSurface + UDIM texture. I notice there are multiple way to do it and one of them are on youtube for Houdini 13 but I guess there is an easiest way to use the new feature in Houdini 14.0.361 with UDIM without any extra operation. I saw we need to use TEXTURE.%(UDIM)d.tif for the path but I didn't make it work. Any help will be much appreciated Cheers J Quote Link to comment Share on other sites More sharing options...
SSFX Posted July 4, 2015 Share Posted July 4, 2015 From what I understand this "%(UDIM)d" is being replace by the proper digits with a vex function "expand_udim". Maybe the mantra surface has not been updated by sidefx to include this function. In the meantime, you can add a vex snippet in your shader that will convert the texture string on the fly if it finds this specific token. Here's a example scene to show you what I mean. You will need to process the copnet to generate the 3 texture files. There is probably a simpler way to do this cause it feels a little hacky, but it works without too much of a pain. Hope this helps. udimWorkflow_v001.hip Quote Link to comment Share on other sites More sharing options...
Jerome_K Posted July 5, 2015 Author Share Posted July 5, 2015 Thanks SSFX ! I gonna have a look at your file exemple Cheers J Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted December 16, 2015 Share Posted December 16, 2015 I know I am a little late to the party but here is two methods I got to work.. jump into your shader and activate Udim filename expansion for whatever maps you need (spec, ref, diffuse etc) then inpunt $HIP/TEXTURENAME.%(UDIM)d.extension the other thing you can do, is to put down a vertex wrangle and input @uv.x *=1/n (n being the number of udim tiles you have). this puts your uv in 0,1 tile space and then you can just stitch your maps together as one long map. this can also be done for the uv.y if you have multiple y rows. Cheers Quote Link to comment Share on other sites More sharing options...
