liquify Posted July 5, 2015 Share Posted July 5, 2015 Hi, I have points that I want to render as volume. As the material, I created a Subnet from a Volume Cloud in SHOP. Without applying any material, I can see the points in the Render View. The issue is after applying the Subnet material, I cannot see anything in the Render View. What should I do to make the points renderable by using the material? Please find attached for the file... foam_test.hipnc (attached file: points with Volume Cloud Subnet as the material) Quote Link to comment Share on other sites More sharing options...
SSFX Posted July 5, 2015 Share Posted July 5, 2015 I'm not sure to understand the issue your having, your setup seems to be rendering fine for me. I switched your shader to the uniform volume shader in the gallery. It usually works great for foam renders. foam_test_fixed.hipnc Quote Link to comment Share on other sites More sharing options...
liquify Posted July 5, 2015 Author Share Posted July 5, 2015 I'm not sure to understand the issue your having, your setup seems to be rendering fine for me. I switched your shader to the uniform volume shader in the gallery. It usually works great for foam renders. Yes, the Uniform Volume material works. I'm curious though, if the Volume Cloud Subnet material works on your system, why do you think it doesn't work on mine? If I use it will look like below (nothing in Render View): Quote Link to comment Share on other sites More sharing options...
