mplay heads up display
Yes, I actually just did that for the first time myself.
Quite simple:
You need to add a parm to your camera: click on the edit parameter interface of the camera, go to the tab For Rendering > Viewport Display > Vieport comment and add that to the camera parameters
After that on the empty line you want to add the npoints hscript expression i.e. `npoints("/obj/...")`
This way you'll see the number on the viewport and on flipbook
