Pancho Posted July 27, 2015 Share Posted July 27, 2015 (edited) In SI it's pretty simple to do this kind of thing. Even use the "Keep" node in conjunction with the "self.vertexIsBorder" one to make the borders stick at their position (Keep node in front of the set point position one). How would I do this in an Attribute Vop? The Smooth operator give really funky results and is hardly usable. Edited July 27, 2015 by Pancho Quote Link to comment Share on other sites More sharing options...
MrScienceOfficer Posted July 27, 2015 Share Posted July 27, 2015 (edited) That same set up with VOPs is definitely a little trickier, as far as I know you can't return an array of neighbor points, so you would have to create a loop, which again can be kinda tricky. I actually did this once with VOPs, mostly to see if I could, it wasn't fun and making it iterate was nearly impossible. You could achieve the same functionality using a point cloud but it will smooth non connected vertices as well. However using a point wrangle node, this is very easy. My Vex is pretty rusty but this still only took me about five minutes int neigbors = neighbourcount(0, @ptnum); vector totalPos = {0,0,0}; for (int x = 0; x < neigbors; x++) { int neighPtnum = neighbour(0, @ptnum, x); totalPos += point(0, "P", neighPtnum); } @P = totalPos/neigbors; If you want to pin borders I would try something like testing if a point only has two connected vertices and not smoothing the point. Houdini's smooth node uses a frequency based smoothing approach, if i remember correctly. http://graphics.stanford.edu/courses/cs468-12-spring/LectureSlides/06_smoothing.pdf I had a better link at one point, but that covers most every smoothing technique. Your node set up, and this Vex code uses Laplacian smoothing. Edited July 27, 2015 by captain 1 Quote Link to comment Share on other sites More sharing options...
Pancho Posted July 27, 2015 Author Share Posted July 27, 2015 Thanks! Almost there. : ) Just two things. a) How do I add the point position of the actuall point to total Pos? totalPos += point (P) is obviously not the correct syntax. Tried to set an outer loop around your code, but the code only iterates once. Is that because P can only get set once in a point wrangle node? How would I loop it? Quote Link to comment Share on other sites More sharing options...
MrScienceOfficer Posted July 27, 2015 Share Posted July 27, 2015 (edited) How do you mean? Add the position of the the current point your smoothing? totalPos +=@P; @P = totalPos/(neigbors+1); You can't really make a loop around it the proper way as in, smooth all points then do it again, I think you would need to use a foreach sop to iterate properly. Edited July 27, 2015 by captain Quote Link to comment Share on other sites More sharing options...
Pancho Posted July 27, 2015 Author Share Posted July 27, 2015 Hi! Yeah, that's what I've meant! Pitty that this can't be done in the point wrangle node. But could it be done if I'd transfer P to a custom attribute and loop over this and apply this to P after the loops? Just an idea .... Quote Link to comment Share on other sites More sharing options...
MrScienceOfficer Posted July 27, 2015 Share Posted July 27, 2015 You would still have the same problem though, you would be iterating the smoothing over the non smoothed connected points. Here's the foreach sop set up, it can be a little tricky to get the settings just right. Quote Link to comment Share on other sites More sharing options...
Pancho Posted July 27, 2015 Author Share Posted July 27, 2015 Man! Thanks! Looking forward to the day when H will get some "proper" SI nodes. There's so much stuff in SI which is simple to achieve with a few nodes and very weired or difficult in H. Hopefully they'll implement the best pieces of SI in order to makes things more comfortable in H. Quote Link to comment Share on other sites More sharing options...
magneto Posted July 28, 2015 Share Posted July 28, 2015 You can return an array of neighbour points using the neighbours function. This is gonna be more like an averaging operation though. Not sure if it's the same in SI. Quote Link to comment Share on other sites More sharing options...
Pancho Posted July 28, 2015 Author Share Posted July 28, 2015 self.Neighbours will return the connected vertices of the current point. If you want to get the nearest neighbours in a particle way, you'd choose "get closest points". You are able to changed the maximum amount of points returned in the array and change the maximum search distance. It's a bit frustrating to feel so handicapped when making the switch from SI to H. Quote Link to comment Share on other sites More sharing options...
MrScienceOfficer Posted July 28, 2015 Share Posted July 28, 2015 (edited) Houdini has the same functionality, using a point cloud you can return an array of the closest points based on range and other parameters. Houdini exposes things at a lower level(or i should probably say in a different way, as VEX is really a shader language) then SoftImage seems too, so in many instances it can be more difficult to do equivalent operations, however because of this Houdini in many instances can be faster, while being just as flexible. It can be a steep learning curve but once you figure out how to port over your bag of tricks, things get way easier. I added a bit more to show what Houdini is really about, this allows you control the weighting and the iterations, without the need to jump into the geometry object. Edited July 28, 2015 by captain Quote Link to comment Share on other sites More sharing options...
Robert Posted July 28, 2015 Share Posted July 28, 2015 Point clouds in Houdini already sort the found points by distance. If you search for 9 points you know you end up with a 3x3 grid of points where the diagonals will always be the last 4 points in the list. You can use this information to get a weighted average by assigning the last 4 points a lower weight. Quote Link to comment Share on other sites More sharing options...
MrScienceOfficer Posted July 28, 2015 Share Posted July 28, 2015 (edited) I had a few minutes, so I added the functionality to pin the borders(works as long as your mesh is all quads), and the ability to blend the pinned border points. Figured I'd stick it up here real quick. Should do everything that you could do with it in SI (and a bit more), you can turn this into an asset and drop it down whenever you need. Never have to think about it again. Edited July 28, 2015 by captain Quote Link to comment Share on other sites More sharing options...
MrScienceOfficer Posted July 29, 2015 Share Posted July 29, 2015 (edited) Okay, so I got really distracted this with today, and really wanted to find a way to find border points in all cases. In most cases one would just see which edges are shared, however I don't believe this is possible in VEX. So what I did was get the neighborCount of all the neighbor points and use a algorithm that tries to figure out if this point is a border point using that information. I actually needed something like this, but I would just remesh first, the quad stuff was a bit of masochistic fun. vector doSmooth(int neigbors, myPtnum; vector myPos) { vector totalPos = {0,0,0}; for (int x = 0; x < neigbors; x++) { int neighPtnum = neighbour(0, myPtnum, x); totalPos += point(0, "P", neighPtnum); } vector neighPos = totalPos/neigbors; return (myPos*(1-chf("weight"))) + (neighPos*chf("weight")); } int isEdge(int neigbors, myPtnum) { //do we have only two edges connected to us then we return 1, as in yes we are an edge point if (neigbors == 2) { return 1; } //count the number of edges of each of our neighbors int hasTwo = 0, hasThree = 0, hasFour = 0, hasFive = 0, hasSix = 0; for (int x = 0; x < neigbors; x++) { int nnCnt = neighbourcount(0,neighbour(0, myPtnum, x)); //printf("%g \n", nnCnt); if (nnCnt == 2) { hasTwo += 1; } else if (nnCnt == 3) { hasThree += 1; } else if (nnCnt == 4) { hasFour += 1; } else if (nnCnt == 5) { hasFive += 1; } else if (nnCnt >= 6) { hasSix += 1; } } //tri meshes if (chi("triMesh") == 1) { if (neigbors > 3 && (hasFive + hasSix) > 3) { return 0; } else if (neigbors > 5) { return 0; } return 1; } //quads else if (neigbors == 3 && hasThree == 1 && hasFour == 1 && hasFive == 1) { return 0; } else if (neigbors == 3 && hasFour < 2) { return 1; } // this case can go either way else if (neigbors == 3 && hasFour == 2 && chi("notWorking")==0) { return 0; } else if (neigbors == 3 && hasFour == 2 && hasFive == 0) { return 1; } else if (neigbors == 3 && hasFive == 1) { return 0; } //do we have four edges and one of those has only two edges else if (hasTwo >= 1 && (neigbors == 4 || neigbors == 3)) { return 1; } else if (neigbors == 5 && hasTwo >= 1) { return 1; } return 0; } int neigbors = neighbourcount(0, @ptnum); if (isEdge(neigbors, @ptnum) == 0) { @P = doSmooth(neigbors, @ptnum, @P); } else { @P = (doSmooth(neigbors, @ptnum, @P)*chf("pinBlendWeight")) + (@P*(1-chf("pinBlendWeight"))); } It works in 4 out of 5 cases and seems to always work if you remesh first, so it could be useful, although there's probably some SOP node I can't think of, that just marks border edges Edited July 29, 2015 by captain Quote Link to comment Share on other sites More sharing options...
anim Posted July 29, 2015 Share Posted July 29, 2015 with all this VEX/Wrangle epidemy don't forget that you can use: Group SOP in Point mode uncheck Enable in Number tab check Enable and Unshared edges in Edges tab that will give you group of border points which you can either use in wrangle as if (!i@group_border) ... or directly run your Wrangle only on !border group (e.g. not border points) however for pure VEX solution to detect border points you can do: int isBorderPoint(int geo, ptnum) { int hedge = pointhedge(geo, ptnum); int starthedge = hedge; do { if (hedge_equivcount(geo, hedge) == 1) return 1; hedge = pointhedgenext(geo, hedge); } while (starthedge != hedge && hedge != -1); return 0; } 3 Quote Link to comment Share on other sites More sharing options...
Pancho Posted July 29, 2015 Author Share Posted July 29, 2015 Great that you put all the effort into this. Thanks! I like that you can dig really deep into H, but sometimes the ease and very efficient low level qualities of SI are lacking. Hope the team creates more simple ways to achieve all this. : ) Quote Link to comment Share on other sites More sharing options...
MrScienceOfficer Posted July 29, 2015 Share Posted July 29, 2015 Thank you Anim, That's a way better solution. I've spent this entire year in the HDK working with tool states, apparently it's melted my brain. Half edges in Vex is awesome though, I hadn't seen that before now. Pancho- I wouldn't say much of this is "digging deep", the group sop solution is really a vital tool in Houdini. Quote Link to comment Share on other sites More sharing options...
