Points to maya via RF export and otl works except rotation problem..
Hi guys, I found 2 ways to export points in maya using RF plugin and otl.
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=141806
Maya reads particles, but I can't force them to rotate.
I Created rotationPP attribute in maya and assigned different vectors, for example:
particleShape1.rotationPP = particleShape1.rfNormalVector
but each of them doesn't look like if I use copy sop in houdini.
any Ideas?
Edited by Anatol
Ok. Particle rotation works with velocity, because particles has velocity attribute. Braking head on point rotation/orientation.
I've got some rotation (im maya) exept rotation along Y axis. I used point sop to set up velocity as $NX/$N/$NZ but I cant get rotation along local Y in maya because velocity is in't quaternion? >__>
So I still have a point orientation problem ((
Edited by Anatol
