Atom Posted August 3, 2015 Share Posted August 3, 2015 (edited) Hi All, I am trying to use an image from a cop network in my environment light. I can see my image in the cop network just fine but when I try to bring it into the OBJ level in the Environment map I get a message from Mantra claiming it can not locate my file. I have typed "op:/obj/cop/OUT", which is a valid path to the result of my image manipulation network, into the Environment Map field of and environment light. Using H14 Apprentice. mantra: Unable to load texture 'op:/obj/cop/OUT' Edited August 13, 2015 by Atom Quote Link to comment Share on other sites More sharing options...
Atom Posted August 3, 2015 Author Share Posted August 3, 2015 Ok, sorry about this post. It seems there is some limit of 768x576 for Apprentice users when transfering images from COP using the op: method. Once I specified the maximum resolution for my file, Mantra quit complaining. It is odd, however, that I can use a 1920x1080 image directly in the Environment Map. Quote Link to comment Share on other sites More sharing options...
