Rob P Posted August 9, 2015 Share Posted August 9, 2015 Hi, I created and unwrapped a book in houdini. I would like to copy it many times and keep all the unwrapp at the same place to use the same texture for all the books. The problem is when I use the copy sop, only the first copy keeps the good unwrapp, the other are anywhere. Does someone have a solution ?? Quote Link to comment Share on other sites More sharing options...
michael Posted August 9, 2015 Share Posted August 9, 2015 can you post your file? Quote Link to comment Share on other sites More sharing options...
Rob P Posted August 9, 2015 Author Share Posted August 9, 2015 here it is It looks like houdini resizes each unwrap according the stamp variables (wich randomize the size of each books) Book Case_003.hip Quote Link to comment Share on other sites More sharing options...
anim Posted August 9, 2015 Share Posted August 9, 2015 you can simply lock the UVs of one book and then attribcopy to live stream which will recreate all books for copy if you want to make it more procedural , you can as well do separate stream that is not stamp() dependent and copy from there Book Case_003_fix.hip Quote Link to comment Share on other sites More sharing options...
Rob P Posted August 11, 2015 Author Share Posted August 11, 2015 thk a lot ! Quote Link to comment Share on other sites More sharing options...
