Smooth a linear curve without losing in-between points.
thibh
Hi guys,
I'm trying to create a path from different cameras.
I manage to create points in Python from each camera's position and then create a linear curve between those points.
Now I would like to smooth the curve to use it as a path for another camera which will be my main cam.
I am using a convert sop to convert my linear curve to a nurbs curve but it's smoothing the curve way too much.
Is there a way to smooth my linear curve and have a result similar to the "Wanted result" curve on the picture ?
Thanks a lot!
post-12817-0-62607200-1439750452_thumb.j
