xcaseyx Posted August 17, 2015 Share Posted August 17, 2015 I recently built a scene to convert a bunch of bgeo sequences exported from another package to VDB meshes. Id create a geo node, drop a file nodes, import the 6 sequences and then merge them, but after Id have 2 merged the merge nodes would no longer work. so I tried merging 2 at a time them merging again.. to no avail. so I tried merging 2, coverting to openvdb, then repeating and merging the 2 vdb meshes.. no avail.. in the end I did it 3 times with 2 merges in each geo node. curious how you all would have handled it. Quote Link to comment Share on other sites More sharing options...
anim Posted August 17, 2015 Share Posted August 17, 2015 ...Id create a geo node, drop a file nodes, import the 6 sequences and then merge them, but after Id have 2 merged the merge nodes would no longer work. .. no longer work how? you should be able to merge 6 geometries with no problem, merge may however complain if there is mismatch in attribs, so maybe you want to keep them packed untill you want to do some operation on them, anyway more info or scene would help Quote Link to comment Share on other sites More sharing options...
xcaseyx Posted August 18, 2015 Author Share Posted August 18, 2015 I solved the issue, the problem was that all the sequences were only cached from X-Y frames not all frames, so when certain BGEO sequences weren't loading they were causing the merge to have an issue. Quote Link to comment Share on other sites More sharing options...
anim Posted August 18, 2015 Share Posted August 18, 2015 if you don't need all sequences for the full range, you can as well just set File SOP/Missing Frame parm to No Geometry to avoid it failing Quote Link to comment Share on other sites More sharing options...
xcaseyx Posted August 18, 2015 Author Share Posted August 18, 2015 yeah I found that out too! I've already redone the original output from cinema 4d. its a bunch of xparticles sims that Im bringing in to mesh in houdini. Quote Link to comment Share on other sites More sharing options...
