NSDesign Posted August 20, 2015 Share Posted August 20, 2015 (edited) Hi All, I've come across this issue a couple of times, and found it really tricky to resolve. Luckily able to go back to a HIP file that was autosaved before the problem existed and had to rename the Houdini X.Y folder that's in the user directory, basically so Houdini will make a new one next it's run. Not an ideal solution, there must be a better way. So the problem stems from the following:- Say you select a node (built-in type), eg SOP/Attribute VOP, Right click and go to the Type Properties, Most of the options, eg. Parameters Tab - shows the message : Can't edit parameters for this operator However on the Scripts Tab - you can add python scripts, events... But when I add some python scripts, I get a message about spare parameters - ...Destroy Spare Parameters. Sorry can't remember exactly the message and options, don't want make changes because it'll cause havoc again. Anyway from what I could tell, Houdini seems to create a new definition for the edited node - sesi::temporary node I think that's what it was called, also appears to actually replace it with this. I couldn't find the original definition for the built-in Attribute VOP. In the TAB menu of nodes there's now 2 Attribute VOP's named as follows :- Attribute VOP(Digital Asset) empty Attribute VOP doesn't allow diving into it It seems I should be able to edit some aspects of the built-in nodes in this way via scripts, I must be doing something wrong or missing something. Also would love to know how to better resolve the node definition when being replaced by sesi::temporarynode... Any help would be great Thanks Nick Edited August 20, 2015 by NSDesign Quote Link to comment Share on other sites More sharing options...
