Meteor Strike/Rain Emitter Question - Emitting from mult. objs
Skar
Hey Guys,
I´m currently having troubles with the smoke container. Having a bullet system, which gives me the emitter data for smoke, somehow the container does weird things. I give the smoke solver multiple objects (meteors) and I thought thats´s it, Houdini will handle it ;)
I don´t have that much experience with the smoke solver, help would be appreciated. A lot.
Cheers,
 Skar
Fireballs_5_testing.hip
not sure what your question is but with a quick look, there's an error in your dopNetwork within the resizeContainer node.
You are trying to initialize it then to track your volume source while it is expecting a bounding box to work.
In /obj/toPyro, lay down on a separate branch a boundSOP after the null named OUT_FOR_SIM
connect another null named something like OUT_container_bounds and reference that null in your DOPnetwork: /obj/AutoDopNetwork/resize_container, in the tab bounds/tracking object/Sop_path.
Smoke will now be generated.
Same idea for max bound object by the way.
