Tyfx567 Posted August 26, 2015 Share Posted August 26, 2015 I know we all want this but has anyone actually found a way to be able to do this over points/ primitives? Bad example but work with me: Say I have a sphere and I want to: for every face delete point "0". This will make a weird triangle shape. for every face In vex I can say something like this: int primnumarray[] = array(@primnum); foreach( int primnum; primnumarray) { int listpoints[] = primpoints(0, primnum); printf(sprintf("%s", listpoints) ); if(listpoints[0] == 0) {removepoint(0, @ptnum); } } The problem if you look at the print, it doesn't set for each face point numbers: 0,1,2,3. Instead it looks at the sphere as a whole and determines the point numbers from that even though I am telling it to iterate over the faces. How can I tell houdini to "isolate" each face just like the foreach node? btw, I know my last bit of the code is wrong I don't know what to do for the last bit. Thanks guys for any help! Quote Link to comment Share on other sites More sharing options...
pezetko Posted August 26, 2015 Share Posted August 26, 2015 Are you running it once as Detail? Or for each Primitives? Let's assume that your sphere has unique points. So each polygon has 4 unique points. What you want to do could be accomplished with this simple code, run it in Primitive Wrangle (Attribute wrangle run over primitives): int geo = geoself(); removepoint(geo, vertexpoint(geo,vertexindex(geo, @primnum, 0))); Function vertexindex() will generate linearvertex number for first vertex (index 0) of each polygon (primitive). Function vertexpoint() then convert this linearvertex number to actual point index. Quote Link to comment Share on other sites More sharing options...
anim Posted August 26, 2015 Share Posted August 26, 2015 or simply: removepoint(0, primpoints(0, @primnum)[0]); the same requirements (unique points, prim wrangle) Quote Link to comment Share on other sites More sharing options...
anim Posted August 26, 2015 Share Posted August 26, 2015 (edited) or if you want it to work on geometry with shared points (fused) then you can recreate each prim without first vertex and delete original prim int pts[] = primpoints(0, @primnum); int newprim = addprim(0, "poly"); for(int i=1;i<len(pts);i++) addvertex(0, newprim, pts[i]); removeprim(0, @primnum, 1); if however you want original prim attrib values back the fastest would be to copy them from original geo afterwards Edited August 26, 2015 by anim Quote Link to comment Share on other sites More sharing options...
Tyfx567 Posted August 26, 2015 Author Share Posted August 26, 2015 (edited) Wow that was fast responses! Thanks so much guys! So unique points in this situation is like where it is isolating the points per primitive? prim 1 = 0,1,2 prim 2 = 0,1,2? Just trying to understand Edited August 26, 2015 by Tyfx567 Quote Link to comment Share on other sites More sharing options...
