Particle Attributes - New vs Old POPNETs
ObiNon
I am learning how to manipulate particles with attributes and I am following a tutorial that uses the old popnet paradigm.
My question is ... If I want to use the new popnet ... how do I pass custom attributes into the network ?
My source is set to 'All Points' - First Context - I have 'Inherit Attributes' set to ' * '.
I see the attribute in the spreadsheet, but I do not see the values getting transferred over.
In the old popnet system I could use an 'attribute' node with a point expression :
point("../../SOURCE", $ID - 1, "my_attribute", 0)
essentially copying/passing the attribute from SOPs to POPs ...
... but that node does not exist in the new popnet.
Thanks  for the help
M
Edited by Mdonovan
hello
there are several nodes that are not available for new pop network in H 14 but are available for old pop network.
for example these nodes
-  Vector Up node
-  angvelocity node
that  I don't know what is its equivalent in new pop network.
Edited by haaranoos
  • 4 weeks later...
hello
there are several nodes in Old pop that I can't find their equivalent  (or new method!)  in new Pop net.
for example attribute transfer in old pop ... how can I replicate it in new Pop net?
( please if you could help , there are others like the 2 of them from the previous post)
thank you in advance
