sessionbeer Posted September 10, 2015 Share Posted September 10, 2015 Hello, I don't understand how I do this and was hoping someone could help me. With this basic script in a Wrangle, set to run over 'Points', it works as expected. When I switch it to run over 'Primitives', nothing happens and it breaks. Could someone please explain how I do the equivalent when it is set to run over 'Primitives' please? For a bigger script I require it to run over primitives, or at least I believe so. v@new_pos; getattribute(@OpInput2, @new_pos, "point", "P", @ptnum, @vtxnum); vector blend = lerp(@P, @new_pos, ch("blend")); @P = set(blend); Cheers Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted September 10, 2015 Share Posted September 10, 2015 Do you want to blend Point position with Primitive position in Over Primitives mode? Quote Link to comment Share on other sites More sharing options...
sessionbeer Posted September 10, 2015 Author Share Posted September 10, 2015 Yea, I think that's what I'm trying to achieve. Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted September 10, 2015 Share Posted September 10, 2015 1. There are more points that primitives, how do you want to interpolate data between points? 2. If you go over primitives, than you are not getting all point positions, because it will not loop automatically over each point in getattribute(), only over one point in each primitive. You need to get all point positions from each primitive and loop over it. Thats for start Quote Link to comment Share on other sites More sharing options...
anim Posted September 10, 2015 Share Posted September 10, 2015 well, there is a minor detail you can't set primitive position using wrangle, so @P = anything; will not do anything you have to set positions of all it's points Quote Link to comment Share on other sites More sharing options...
sessionbeer Posted September 10, 2015 Author Share Posted September 10, 2015 Maybe it's easier to explain with a scene so below is a stripped down version. When you play the scene and look inside (solver1/mover) - you'll notice that the points move at different speeds. My wrangle node is trying to get the previous frame point position, and the add a vertex to the new point position. But for some reason it isn't working correctly. On the other side I have dropped a tail Sop down and that is working correctly, so I'm not sure where I'm going wrong? I maybe of course, be going about this entirely wrong so I would appreciate some advice. Thanks https://dl.dropboxusercontent.com/u/2802779/Wrangler_A1.hip Quote Link to comment Share on other sites More sharing options...
